跳转到主内容
加入维修社区 - 创建账户
CPU fried, can't acces ssd
HI
A couple of weeks ago, began to smoke as I plugged in a faulty adapter.
I don't want it fixed as I've been made very clear that that's not worth the money, but I want to recover my data. (2 years of music production)
As the ssd is embedded on the logic board this is a hard task, I've contacted a lot of services already and a lot of people already worked on it, but no succes.
The CPU overheats and is broken and with the logic board as the only way to read the chip it seems that I'm all out of options... can somebody please help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Because sadly,I don’t have the proper tools and knowledge. I would love to find someone who can fix this or can help me fix it myself
完成的
@casvandecruys what country are you in
完成的
I live in Belgium
完成的
添加一条评论
2个答案
最有帮助的答案
Sadly, you need a certain amount of a working system to gain access to the Flash chips data!
While I understand your frustration, you will need to get it partially fixed at least long enough to pull your stuff off.
This series encrypts the data on the fly so unless you have the needed pieces working within the logic board there is no hope of pulling the data.
So you need to ask your self how valuable is the data? Not the worth of the system!
There are a few people with the needed skills to patch the system together, but I would need to know where you live (country and nearest major city) then we can try to find someone who can help you.
这个答案有帮助吗?
得分 2
6条评论:
Hi
I’m in Belgium I can easily go to Antwerp or Brussels!
It would be amazing to find one of the few people that can fix it!
I’m curious for the quote
完成的
@casvandecruys - Sorry for the wait, I personally don’t know anyone in Belgium, the best I can aim you to is TheBookYard in the UK. See if they can aim you to someone TheBookYard - Contact info they also repair.
完成的
Hi Dan
Thanks a lot for your help!
I will contact them right away!
完成的
@casvandecruys - Do let us know how it goes.
完成的
HI Dan
The Bookyard said there was nothing they could do, they don't do memory retrieval and think it's very hard to replace the cpu.
Do you have another option?
完成的
显示更多的1条评论
添加一条评论
Hello, this MacBook have intel cpu, thats mean the cpu can be also changed, is not bind with other components like ipads, iphones or M1 devices. But to read data is only way to make this laptop working. Also when you take the nand chip to Programmer data will be not possible open becouse is encrypt.
这个答案有帮助吗?
得分 1
12条评论:
So you say the the only fix is replace the cpu and then it would be possible to retrieve the data?
I would love to find services that can do this in Europe!
完成的
I mean when the cpu is need to be replace is possible, also some power supplies for the cpu can be KO, but its also possible to replace. Depend how many components is dead. When is too much dead then is better make swap. Its mean také important components for unlock the data and solder on working board. For data unlock must working T2 chip, nand chips, eprom and maybe wifi chip. When is all this chips work can be soldered on another board, this will solve the data.
完成的
Hi
Can you find somebody that provides this service? Do you know a company near belgium?
完成的
@casvandecruys I'd contact these people https://www.macpc.fr/ as well as www.resq-repair.com See if they can help you. They are known to the European community and hopefully they can guide you a bit better.
Maybe @vojtech59738 can help you out further.
完成的
Sadly i dont have infrared solder station, only hot air. This cpu is allready big.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Cas Vandecruys 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 273
