When I try to erase my MacBook this happens
Well, I’m following a YT tutorial to erase my MacBook core 2 duo without a pendrive and this shows up, I’m using the command+S technique to erase it.
Now it doesn’t even boot up to the os and just keeps on the Apple loading logo, I’m attaching what showed up when I tried to erase it, and what is happening now.
Thanks!
2条评论
What do you mean you tried to erase it? Did you try to reinstall the OS?
or did you take out the disk, wiped it and put it back in?
由 cédric coco 完成的
Well I just pressed command+S and it bottled up on the dev console then I typed
Mount -uw /
Then
rm /var/db/.applesetupdone
And
Shutdown -h now
That was it, now it doesn’t turn the os on again
由 Oslândios Geral 完成的
