跳转到主内容
加入维修社区 - 创建账户
15" laptop manufactured by Dell at the end of 2016. The laptop is very configurable, uses 7th generation processors and has a grey plastic chassis.
Laptop doesn't boot after taking apart a putting back.
So pretty much title but at first the fans started spinning full speed and the batter indicator lit up, nothing else. When I opened it again to look what was wrong, after disconnecting a ribbon cable (I think it lead to the monitor) I touched something with it and the battery indicator flickered, and now it won't even show signs of life. I think something short circuited but don't see anything on the motherboard.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Firstly, open up the computer and make sure that all the cables are securely connected to the motherboard. Good? Next, plug the computer into an external monitor and try powering it on. If the cable you damaged was the one attached to the display, then you may have shorted your display out. The red box in this image is the display cable. Is this the cable you damaged? If not, what cable did you damage?
Thirdly, what does the computer do? Does the power light come on? Charging light? Keyboard backlight and fans? If the charging light doesn't come on, then your battery just may be fully charged. If none of this works, then you may have damaged the motherboard.
Good luck and let me know how it goes!
这个答案有帮助吗?
得分 0
6条评论:
So the cable in the red box is the cable that caused the light that displays the battery status to flicker. As I said nothing turns on now when i try to plug in a charger and turn it on.
完成的
Also can a mother board be dead and look fine? Either I overlooked something or I just didn't notice it, because I don't see anything bad about it.
完成的
The cable in the red box is the one that goes to the display, not the battery light.
完成的
Well i think it's dead but do you know which one would i have to replace?
完成的
which component
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Where Moni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 306
