跳转到主内容
Dell Inspiron 15-5567 Back Cover Replacement
你所需要的
  1. Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 15-5567 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Orient the laptop with the back cover facing upward and the INSPIRON engraving reads legible (not flipped).
    • Remove 13 M2.5x8mm screws using a Philips #0 screwdriver.
    • Remove two M2x4mm screws using the same screwdriver.
  2. Dell Inspiron 15-5567 Back Cover Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15-5567 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Insert the blue plastic opening tool into the crease of the CD driver, and pop it open.
    • Slide the rest of it out with your hand.
  3. Dell Inspiron 15-5567 Back Cover Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15-5567 Back Cover Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15-5567 Back Cover Replacement: 步骤 3 中的图像 3,3
    • Remove three M2x2mm screws underneath the CD driver with the same Philips #0 screwdriver.
    • Place the blue plastic opening tool in the crease of the cover and push it upward to open the back cover.
    • Grab the corners of the cover firmly and lift it up.
    • Some parts are weaker than others; open it gently from corners.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 35
总计 2,415
