跳转到主内容
2022年13英寸MacBook Air的维修指南、支持和故障排除信息,采用苹果的M2 SoC。于2022年7月15日发布,型号为A2681。
44 个问题 查看全部
USB-C Thunderbolt does not work after spilled liquid
Hello everyone!
I have a MacBook Air M2 A2681 that got wet, after drying it the best i could, the thunderbolt ports have stopped working. How can I know if only the ports have been damaged or is it something on the motherboard? here on my country it is not easy to get a new port but i will try to get one to test.
I was able to remove them and tried to clean up with isopropyl alcohol
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You can probably tell just by looking if it’s the port. Try looking with a flashlight and see if you spot any corrosion. Otherwise, you’ll want to open the machine up and see if there are any signs of liquid inside. You can remove the ports pretty easily and just see what they look like. If there’s corrosion on them, but internals look clean, probably just the port. You might even get it to work if you clean up corrosion with some isopropyl alcohol and a cotton swab. Depends on what the actual issue is. Liquid damage in the port can cause electrical damage to board components, but I have seen lots of these that are just the port itself.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for the quick response. i will open again and try to take better pictures
完成的
添加一条评论
添加你的答案
Victor Adrian Toledo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 435
