跳转到主内容
Hover 1 Alpha folding E Scooter repair manual
6 个问题 查看全部
How to remove/reinstall the rear tire on a Hover-1 Alpha folding scoot
The alpha has a motoring the rear wheel. Repairing a flat in the back tire is a ridiculously difficult task. Reassembley instructions would be very helpful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Here's a video on how to do it:
https://www.youtube.com/watch?v=aML9BBod...
这个答案有帮助吗?
得分 1
1条评论:
Nope, that video is not for the Alpha. The Alpha has the motor in the rear wheel and many more spacers and washers it the axle
完成的
添加一条评论
You need, large tyre levers (3), washing up liquid and two people. I take it you have removed the motor from the wheel.
Put the tyre and tube on the wheel. Spread the washing up liquid around the side of the tyre and push as much onto the wheel as you can. Whilst holding that in place have another person start feeding the tyre on with the tyre levers. When near completion you have to use brute force to get the last bit on.
Replaced loads at work so hopefully this will help you. Don’t use pushbike levers as you don’t get enough leverage, you need ones at least 12 inches long. Try not to pinch the tube.
这个答案有帮助吗?
得分 1
1条评论:
Thanks this helps with how to replace the tube. I was also interested in how to reassemble the rear wheel to the frame. I'm not sure which side the spacer washer is installed on.
完成的
添加一条评论
Hover support sent my a PDF showing how to remove the rear wheel. Thus should be all I need to reinstall it as well.
这个答案有帮助吗?
得分 0
1条评论:
Can you send me said pdf mjtdrb@gmail.com
完成的
添加一条评论
添加你的答案
sfaheysd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 75
总计 273
