跳转到主内容
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
cd/dvd drive is missing from my system
Dell Inspiron 1525 does not see the cd/dvd drive. I can open the drive, but when closed, the drive light flashes several times and nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
What Operating System are you running on your Dell?
完成的
marsyoung, check your BIOS on startup. Make sure your drive is enabled.
完成的
thanks all - I had this problem - not found in bios either - I took the back off and I just reseated the drive. Perfect - all found
thanks again
完成的
添加一条评论
5个答案
已选择的解决方案
Got it fixed - finally read a suggestion to check that dvd drive is seated firmly in the laptop - was slightly dislodged. Thanks to all for your advice!!!!
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
Power off, flip it over and remove/re-insert the drive. I've seen optical and hard drives across various brands and models where the drive will get slightly loose.
这个答案有帮助吗?
得分 3
添加一条评论
change ur lens
这个答案有帮助吗?
得分 1
1条评论:
I'm not sure why you recommend changing the Lens. The fault stated is that the CD/DVD drive is not present and not that it is unable to read discs.
完成的
添加一条评论
Assuming that you are running Windows on your Dell, as this is a common problem, then there is a Microsoft FixIt application that usually resolves the missing DVD drive issue. Below is the link http://support.microsoft.com/mats/cd_dvd...
If this does not work then there is also a registry fix, removing the upper/lower filters. This can be done by following the directions below;
''Run Command Prompt (type CMD in the Start Menu on Vista/7)
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters that appear on the right hand side.''
Hope this helps,
Wes
这个答案有帮助吗?
得分 0
添加一条评论
Delete upper and lower filter from registry to retrieve your DVD drive from my computer.. Follow this link for more instructions.
http://www.techxure.com/2012/11/dvd-driv...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marsyoung 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 14,286
