跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 个问题 查看全部
I have a hard drive from an old server and I can not get it to work
hi
Somebody gave me an old windows server for parts.I managed to get one hard drive out of it that was 250Gigs. I connected it to an external dock but it only showed up in the disk utilities and not in the windows file browser and i could not do enything with it.
IF someone knows how to fix this please respond.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
please give us the specs on the drive, i.e. type of drive, brand, model number. Also what are you hooking it up to.
完成的
@mayer i have posted a picture of the hard drive and the dock i am using
完成的
添加一条评论
2个答案
最有帮助的答案
If the drive shows up in Disk Management then you should be able to partition and format the drive. This link may help you troubleshoot your drive issues. If you still continue to have issues with the drive take a screenshot of Disk Management with the drive and post it here. Good luck.
这个答案有帮助吗?
得分 2
1条评论:
It's entirely possible the drive was part of a RAID array and thus will be unreadable without the other drives in the array, so yeah, repartition and reformat and see where you are after that.
完成的
添加一条评论
I found the solution i had to open windows disk manager as an administrator and reformat the drive
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vagelis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 8
总计 48
