跳转到主内容
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
20 个问题 查看全部
Replacing my rear-view mirror
I knocked my rear-view mirror off. The little metal piece has already been put on but I was told to wait 24 hours to actually pit the mirror on it. The guy left a tool to do it with but i don't remember what exactly he told me to do...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Is this an internal or external mirror?
完成的
添加一条评论
1个答案
已选择的解决方案
Once the metal piece is attached and the adhesive has cured, then take your mirror and look at the base that attaches to that metal piece. There is a set screw. That's likely what the tool he left for it is for. There may be a plastic cover covering it. Open it up to access this screw. Then go ahead and loosen the screw (don't take it out! Is a pain to put back in with mirror in place!) Then take the mirror and slide the base down onto the metal anchor from the top. Make sure it's on all the way, tighten the screw, put the plastic cover on, and you're good to go
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sheila Kay Boxley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 81
