跳转到主内容
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
78 个问题 查看全部
My oil cap pops off where is the pressure comming from?
Where and what could be the cause
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
how many miles are on the truck? What engine do you have?
完成的
添加一条评论
1个答案
If the cap gets blown off, there is too much pressure in the crankcase. Blow-by can be caused by piston rings that are worn out. A cylinder with worn out rings will have low compression and will likely cause a misfire. These piston rings need to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Taitano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 11
