跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Power button replacement not working
Hi,
I did already fixed some Iphones, but this time I have no clue whats wrong. I replaced the powerbutton from an 3GS, the silverbutton was gone...(but still working)...
So I replaced the button like explained in the guide, but the new button does not move up or down, it is just stuck. The guide says the metal handle has to face down, I did all that. I can use the screws again to fix it and all, still the button itself is not moving/working? Anyone got an idea? I guess I simply overlooked something.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for the tips and will try it out asap. :)
完成的
添加一条评论
1个答案
最有帮助的答案
They can be quire fiddly to install, I have done many myself. Also bear in mind that the rear case might be too tight around the power button. I have had a few where I have had to use a small file and make the power button hole a little bigger for the button to move in and out.
Also sometimes if the screws are done up too tight it can stop the button from operating correctly.
这个答案有帮助吗?
得分 1
1条评论:
+..most times it's been overtight screws, they shouldn't be biting into the plastic but merely holding in place.
完成的
添加一条评论
添加你的答案
edwood110 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 629
