跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Replacing battery from iFixit
I'm preparing to replace battery in my iPhone 6s Plus. I already have the Toolkit, so i'm just after "Part only"
However, watching video, it looks simple enough. After disconnecting battery form the connector, is it "required" to also disconnect the display assembly from logic board? This is no where near the battery, it just connects the display (from the top case to the bottom, so i assume disconnecting this is from a "safety perspective only".
Can i just go ahead and remove battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi na na,
Yes, you can take out the battery without removing the screen. It's a safety procedure to ensure the display cables aren't damaged in the process of fiddling with the battery. As a matter of fact, the introduction in the battery replacement guide comes right out and tells you that it can be done without taking off the display.
This guide instructs you to detach the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while peeling the battery out of the iPhone, you can skip the display removal and go directly to the battery removal steps.
iPhone 6s Plus Battery Replacement - iFixit Repair Guide
It also suggests that removing the Taptic engine is optional as well, but I'd suggest doing so. It's not difficult and will give you a flatter angle to pull the battery adhesives out, which helps keep them from breaking as you're trying to remove them.
Good luck with it; let us know how it goes!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
na na 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 171
