跳转到主内容
The Anova Precision Cooker with Bluetooth and WiFi is a device designed to use sous vide (pronounced “sue-veed”) to cook food to precise temperatures.
6 个问题 查看全部
No Power when Plugged into outlet.
Bought a 2019 anova precision cooker bt wifi. Used only twice. Used yesterday. Went to use it again today and I get nothing powering up when plugged in. No visible switch or fuse. Tried three direct wall outlets but still zero power. Is this fixable I am sure as hell not dumping another $180 to replace it!!!
What would be the most likey cause for no power? Is this fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @richardmulawa
There's a fuse shown in Step 4. of the ifixit Anova Precision Cooker BT WiFi Teardown guide.
Select the small image, 3rd to the right at Step.4 to see its location.
If it is blown, then as to why this occurred would have to be further investigated. Fuses do not usually fail for no reason
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Richard Mulawa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 45
总计 426
