The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
这个答案有帮助吗?
but it can detect my other SSD
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 96
总计 1,154
1条评论
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
由 Mahedi Hasan Suman 完成的
