跳转到主内容
Western Digital (WD) Solid State Drive (SSD) Available in 2.5” 7mm and M.2 2280 models 120GB or 240GB
4 个问题 查看全部
The ssd is not showing up
The SSD is not showing up when connected to my PC. It has a lot of data in it. I had used it for transferring data. But now it is not showing up when connected to the pc. No drive is found.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
SSD card not showing in my PC. The SSD card is ok or not ok. Pls advice. What to do? What is the solution
完成的
添加一条评论
1个答案
最有帮助的答案
Well The BIOS will not detect a SSD if the data cable is damaged or the connection is incorrect. Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
这个答案有帮助吗?
得分 1
1条评论:
but it can detect my other SSD
完成的
添加一条评论
添加你的答案
thrippakulath unnikrishnan 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 66
总计 1,117
