I have the same issue with my Power Suppl
I have the same issue with my Power Supply. The two resisters R404 and R405 are blown. I am not able figure out what they are based on color ring sequence does not exist. Sequence is green, gold, silver, gray and blue. Was told by a tech at Digi-key that gold and silver should be at end of sequence because they are tolerance values. How do I figure out what I replace them with? Alan
Update (05/08/23)
I have the power supply issue. Resistors R404 and R405 are blown. Color sequence is green, gold, silver, gray and blue. That sequence does not seem to exist. Help.
2条评论
@alzal1 that is correct. On a 5 band resistor you would expect ring 4 and 5 to be either Gold or Silver. You can't have any other color following those. At this time the best thing to do would be to let us see what you see. Post some GOOD image of those resistors with your QUESTION. That way we can see what you see. Edit your Question and use this guide Adding images to an existing question - iFixit Repair Guide
由 oldturkey03 完成的
@alzal1 the only time I have seen a band following the Gold one is on a 6 band resistor where it is the temp coefficient. Darn that is a new one for me. Maybe @tech_ni @dadibrokeit or @jayeff can give you a better answer.
由 oldturkey03 完成的
