跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Lost Nut for Logic Board Screw #13
While swapping out my front display, I lost the nut from the yellow screw in step #13 (iPhone 4 主板更换). I was wondering anyone knows of a place to buy this piece? For the time being I just bent the Y bracket down to ground the board, but I would really like to find a replacement. Here is a picture of what it should look like http://i152.photobucket.com/albums/s199/....
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
7个答案
已选择的解决方案
This screw and nut are not necessary components. Sure they help hold the shield down. But not necessary for perfect function of the iPhone.
这个答案有帮助吗?
得分 1
添加一条评论
Wrong answer above. The nut serves two purposes: Helps hold the mother board down AND serves as a ground for the wi-fi. This nut is frequently lost when someone replaces the digitizer and they often without it they have poor wi-fi reception (sometimes no wi-fi signal at all).
这个答案有帮助吗?
得分 0
2条评论:
hmm...on the link provided above in the question it isn't the wifi screw (marked green in the picture) that Chris Li is missing, but another screw in the bend of the logic board (marked in yellow) nowhere near wifi antenna ground. Are we all talking about the same screw or is this something you've learned yourself? afaik losing the screw that is marked in green on that photo, renders your wifi unusable...not the yellow.
完成的
hmm interesting, thanks for the info. haven't found/replaced the nut on my phone and wifi seems to be working fine, interesting.
完成的
添加一条评论
I've been missing that nut since last june and I've had perfect wifi.
这个答案有帮助吗?
得分 0
添加一条评论
Same issue I lost the nut on the logic board that the yellow screw goes into (well it broke off) and no wifi I have to put my phone on top of my router to get a signal.
Also the green screw has something to do with reception if you take that out wifi works but very weak.
这个答案有帮助吗?
得分 0
添加一条评论
Snapped off the entire corner that the grounding screw is in because I forgot to remove it. &&&$. In the instructions they should really stress hidden screws. Hopefully if I put it all back together it will still work as everything will still be touching, though it won't be 100%.
这个答案有帮助吗?
得分 0
添加一条评论
I opened 5 iPhone 4 so far and 4 times out of 5 that nut came away, even if I pay attention; that's a very annoying issue.
I think that nut is vital for the gps signal, because after each disassembly the gps wouldn't work. As above-mentioned, I always bend the two branches of the Y upwards and downwards respectively and the gps starts working again.
It could also be a coincidence and the week gps signal could derive from removing the battery and causing a loss of gps data (ephemeris), any ideas?
这个答案有帮助吗?
得分 0
添加一条评论
I've actually lost the nut, which has lead to the microphone not working when making calls!
The only fix I could find was to stick the screw in place with a piece of card, so it still makes contact, and now I can make phone calls again.
Even so, if anyone knows where to get a replacement nut for the screw, that would much appreciated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,363
