跳转到主内容
The Explorer saw significant exterior, interior, and suspension updates for the 1995 model year, losing all its exterior bodywork shared with the Ford Ranger.
Transmission stuck in 4x4 low
My 1997 Sport Trac is stuck in 4x4low
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@michaeldaigle AT I assume. What have you tried? What happened that it got stuck? Anything unusual?
完成的
添加一条评论
1个答案
If you can't get out of 4low, disconnect the batty for the car and wait about 5 minutes, then try shifting out of 4 low (Make sure you're on N)
And if that does not work, try pressing the 4high button and shift into reverse, neutral, drive, neutral, and reverse. If you do this about 5 to 10 times it should catch on and get out of 4 low
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Daigle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 161
