Manufacturer Part Number 100015685 Serial Number: G5KDCZ0670L5
maggie chastain @maggie58
声誉积分: 57
发帖于: 2023年5月1日
My SD card is stuck How do I remove it?
这是一个好问题吗?
mike @aactech
声誉积分: 31.1千
9
13
66
发帖于: 2023年5月2日
I suggest a magnifying glass - your phone may have this feature - and look at the card carefully to see where it is stuck. Small needle-nose pliers can be used to gently release and pull the card out.
这个答案有帮助吗?
jayeff @jayeff
声誉积分: 521.3千
11
398
1.5千
发帖于: 2023年5月3日
Hi @maggie58
Try gently pushing the SD card in and then let it go.
It should spring back far enough for you to grab it and pull it out.
If you want to insert a new SD card (it only goes in one way so don't force it) push it in until it clicks into place.
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 168
