跳转到主内容
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 个问题 查看全部
2DS XL WiFi Glitch
My 2DS XL used to work perfectly fine on wifi until recently, it’ll say disconnected, then wifi, and be on StreetPass for a while before disconnecting and restarting the cycle, and every time I open a game or all the wifi is off.
It’s not my wifi either because like I said it used to work and I’ve also used my mobile hotspot and it doesn’t work either.
How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Let's hope this is a software issue. Try:
  • Deleting and recreating your wifi connection
  • Turning wireless communication/NFC off and on
  • Rebooting the system
  • Updating in safe mode
If all else fails, a system format should definitely fix it, but it will also delete all your data. I'd only recommend that as a last resort
这个答案有帮助吗?
得分 1
5条评论:
I’ve tried all those things and I can’t factory reset because I have a NNID attached to the 2DS and it needs wifi to reset that off the 2DS
完成的
@ferroza There is a way to remove an nnid without wifi, but you need CFW. If you're interested, head to 3ds.hacks.guide. Once you've read through the intro pages, you'll find a prompt asking for your system version. If you have a compatible flashcart, I recommend you scroll past it and click "ntrboot". Otherwise, keep reading. If the prompt recommends you any exploits you can't use, join the discord linked in the troubleshooting page and explain the situation, someone there can probably help you.
Once you finish the finalizing setup page, head to https://3ds.hacks.guide/godmode9-usage#r... to remove your nnid
完成的
When I reset it after all that junk, the Wi-Fi problem still persisted at setup.
完成的
@ferroza As in, you factory reset it and the wi-fi is still broken?
完成的
yeah just hold the x button and the start button and click on the wifi network it should show you an error code to why it isnt connecting
完成的
添加一条评论
添加你的答案
Ferroza 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 33
总计 809
