跳转到主内容
Repair and disassembly information for Samsung's flagship S20 Android smartphone, released in March of 2020.
Trying to reseal back glass
Hi recently I just repaired my s20 battery but now I'm having a hard time getting the back glass back on, I removed the adhesive and put on one of those 2 pound ebay waterproof green seals on the back glass and stuck it on. However on the sides of the phone I can't seem to get it in all the way and there is a small gap. I want to make sure the phone is sealed properly. How else can I seal it so that the back glass is all the way back in like brand new. And is waterproof resistance completely gone? Is there any way at all I can bring it back? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you remove the old adhesive from the glass and the chassis of the phone? Try and find genuine Samsung adhesive. Aftermarket stuff is absolutely garbage.
完成的
添加一条评论
1个答案
Hi Ali,
Yeah, there's something screwy going on if the rear cover doesn't fit any longer. If everything is done correctly, it should sit down exactly on the frame all the way around. Given that the rear cover is glass, that means it's not a matter of having been deformed when you removed it; glass just isn't that flexible. So you're going to have to go over your work again and figure out where the problem is.
I'm looking at the battery replacement guide and there are three parts that get removed; the battery itself, of course, the wireless charging coil, and the lower speaker. Most likely one of those things isn't sitting inside the phone quite right and is keeping the cover from seating correctly.
So yeah, go order yourself a couple more sheets of precut adhesive and resign yourself to opening it back up. Remove the adhesive first so you'll be able to do test fits without it sticking down, then start disassembling again. I'd try taking off the wireless charging coil then see if the cover fits. Put it back on, then take off the lower speaker and try again. Pull the battery then refit everything except the battery and do a test fit. Somewhere along the line you'll see which of those parts is getting in the way, and once you do you'll have to figure out what to do about it; usually it's a matter of making sure the part fits in where it's supposed to go. I'd double-check the replacement battery against the original to make sure it isn't thicker, which would cause the kind of problems you're seeing.
By the way, when putting the rear seal on it usually goes onto the phone chassis rather than the rear cover. There's no specific guide for putting that on, but here's a general guide that should work fine.
How to Replace the Back Cover Adhesive (Frame First) - iFixit Repair Guide
Good luck; let us know what you find!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali Umer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 37
总计 683
