Nintendo 3DS XL Streetpass not working after repair
I recently repaired my Nintendo 3DS XL top screen, and took it the day after to my friend's place so we could play together. I noticed that the whole time we were playing, Streetpass didn't activate for either of us. Both of our 3DS showed that Streetpass was active and had a "signal." We both tried deleting the others mii profile from the plaza, but that didn't work either. I think there might have been something that I knocked or pushed over inside of the 3DS that might be preventing Streetpass from working properly. Anybody know what component this might be, or if its not a motherboard issue, what can I do to fix this?
4条评论
How long was it since the last time you streetpassed? You can only tag each person once every 8hrs as far as I can tell. Also, were they in sleep mode together for a few minutes?
由 darth mango 完成的
@darthmango From the repair it took about 2 days to fix, so I know it was more enough time for streetpass to refresh itself. We did put our 3DS's in sleep mode for a bit but still nothing happened. We each also tried deleting the others' Mii profile from our streetpass plaza, but nada.
由 Gordon 完成的
@gordon70979 You could check the wifi card, though I'm not sure streetpass even uses it. I'm guessing the 3ds's can't detect each other, but I have no clue what to do about it
由 darth mango 完成的
@darthmango I'm probably going to go to another friend and see if we can make it work. If not I'll try resetting it and see what I can do from there. If the 3DS doesn't use the wifi card for streetpass, do you know what component might be used?
由 Gordon 完成的
