跳转到主内容
加入维修社区 - 创建账户
Disc drive won't let me put a disc in, nothing in there
I can't put a disc in, there is something blocking me from putting one in, right at the front, and there isn't a disc in it - i have tried rebooting, restarting, ejecting (even though there isn't a disc in it), etc. It did this before, and fixed itself somehow, but it's not budging now. Feels mechanical, like some part of the eject mechanism is stuck on eject and not going back in???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
2条评论
Did you have any luck on this issue?
完成的
I changed my car recently away from skoda I would prefer a skoda but you can't put in a music disc into the skoda cars a comment would be welcome
完成的
添加一条评论
15个答案
已选择的解决方案
If you are unable to push the disc in at all then it certainly does sound like a mechanical issue. It sounds as though the mechanism that stops you from inserting a disc when another disc is present has come loose. I would recommend replacing the drive rather than trying to repair it, but it may be worthwhile removing the superdrive to take a physical look to make sure nothing has sneaked its way inside.
Hope this helps,
Wes
这个答案有帮助吗?
得分 3
15条评论:
I would recommend everyone to try my hint before replacing it. It worked for me so... Just in case... :)
完成的
Sometimes the wrong answer gets accepted.
完成的
I can insert the Dvd but it pushes back out instead of running it in..
完成的
I tried inserting the dvd (elder scrolls online) but the mechanism just won't work.
完成的
Gabriel Mattos has the correct answer. Not just remove the drive. The tray mechanism is stuck. To force eject a disk that is stuck, open TERMINAL in the UTILITIES folder of Applications inside FINDER. Run this command no parentheses (drutil eject disk) but if there is NO DISK and you can't push a disk in, put in (drutil eject tray). Note that you may have to do it several times, up to 20 Ive heard. For me, 2-4 usually works.
完成的
显示更多的10条评论
添加一条评论
最有帮助的答案
Guys,
I have solved this problem by simple running this line on terminal:
drutil tray eject
Hope it works.
PS & 1st UPDATE (18/10/2016)
So... I had the same issue again and I wasn't able to solve it right away. This time I've had (like some of you guys) to run the command several times. I ran it for like 20x before it finally wake up the drive and release it.
这个答案有帮助吗?
得分 80
99条评论:
omg that was beautiful!
完成的
Thanks Lucille. I was actually quite surprised it took only this. Do hope it works for everyone else. :)
完成的
Hero. Thanks a lot mate!
完成的
You're welcome, bro! :)
完成的
Thank you!!!! Worked like a charm!
完成的
显示更多的94条评论
添加一条评论
Press and hold the mouse or trackpad button down when you power it on and keep holding it down. This forces a disk eject, or at least tells the mechanism to to go through its eject cycle. This may move the mechanism to it's fully open position for you.
这个答案有帮助吗?
得分 4
1条评论:
The button reboot worked for me after the Terminal command didn’t. On PowerBook g4 2005 Leopard
完成的
添加一条评论
There are sometines screws on the top of the unit that are to be taken out before installing. It's usually clearly marked to take them out but possibly the label was missing when the unit was installed
这个答案有帮助吗?
得分 1
1条评论:
Restart, hold eject and when you hear the noise of the drive opening sneak a disc in.
完成的
添加一条评论
I find this is due to iTunes failing to unmount the disc or something, even after it successfully ejects it. Thereafter you need to reboot in order to insert a disc. My workaround: quit iTunes before ejecting a disc. then Eject via finder. The restart iTunes. Disc loads no problem.
这个答案有帮助吗?
得分 0
添加一条评论
I have a HP 'puter with a 'Tower' ,. One CD/DVD disk drawer would not open when button was pushed. Go to 'COMPUTER' and click on it and a selection of various drives will appear on your 'puter. EXP~~ A drive, B drive, C drive etc etc. Determine which drive icon will not slide out and RIGHT click on the icon. A box drops down . Select 'EJECT' and it should open with ease.
这个答案有帮助吗?
得分 0
添加一条评论
Solved: Just press Eject button for 10-20 Second until "CD In" disappear. That is it. Don t make it complicated. It worked for me
这个答案有帮助吗?
得分 0
1条评论:
That's wonderful, Amir.
完成的
添加一条评论
just remove the sata/ide cable then press cd/dvd drive open button
thats will worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
this is happening to me too! GAHHH! so annoying. so i tried the terminal thing and i just typed drutil tray eject a bajillion times. each time it made a different noise but after i typed it twenty or so times it stopped and still wouldn't let me put the DVD in. i have a pretty old macbook but i feel like at least something should solve this problem!
这个答案有帮助吗?
得分 0
1条评论:
I have tried this hundreds of times but it never worked for me either!
完成的
添加一条评论
I tried this 30 + times but it didn't work. Bought an external drive now!
这个答案有帮助吗?
得分 0
添加一条评论
I have an external drive that has the above problem. So: no disk in drive, drive unplugged: I gently tapped the drive on the desk with the opening DOWN about five times. Then I dragged a SMALL nail just past the opening to try and pull out anything that may have been dislodged. Nothing came out. So I did it again. Still nothing came out. So I popped a disc in that I didn't care about into the drive and BINGO... It accepted it!
Hope this helps someone. - Lindy
PS: Hope this didn’t enter twice as I had to sign up before I could comment ;-)
这个答案有帮助吗?
得分 0
添加一条评论
I tried every to take apart and visually inspect my iMac nada good idea. after 2 hours and a whole lot of frustration I opened Terminal and entered a new command this - drutil tray eject - as suggested. 20 seconds later I was free at last. Out popped the unreadable disc. It didn't even show up on my desktop. Wowee. Thank you, thank you.
这个答案有帮助吗?
得分 0
添加一条评论
I tried everything and nothing worked. I found the answer in the comment section by dewolfeinsheepsclothes. Restart the computer. While restarting hold the eject key (Top right on mac). Hold until the desk top appears, quickly put in a cd. Finally after months I can burn cd’s again.
这个答案有帮助吗?
得分 0
1条评论:
Just like all the tricks I've tried, it did not work!
完成的
添加一条评论
I tried over 50-60xs still not able to insert CD into the my 2009 MacBook Pro SuperDrive 😞☹️
These were the steps I took:
Applications->Utilities->Terminal->Shell->New Command->drutil tray eject (heard few tiny clicks but that was it). Tried to insert CD but still unable to…CD goes in about 1/4 way then like hitting a wall 🤷🏻‍♀️🤦🏻‍♀️
Please let me know if I missed some steps or any other suggestions would greatly appreciated!!!
Thank you so much!!!
这个答案有帮助吗?
得分 0
1条评论:
Hey Linda, no, you did every step pretty much right. The command works but it isn't really so much different from pressing the eject button. Just a solution that would “bypass the physical action” of ejecting. :/
It did work for me in the past but unfortunately as for every device… It could be a matter of replacing it or at least giving it some sort of maintenance.
The good thing is, it isn't really difficult or even expensive to replace it. There's even a very good tutorial around here for it:
MacBook Pro 13" Unibody Mid 2009 Optical Drive Replacement
I guess that's it. Wish you good luck with that. ;)
完成的
添加一条评论
There is a simple cause for this. Its a result of failure of the OPTICAL DRIVE, and needs to be either replaced, or SOMETIMES I'm able to take cover off, clean and lubricate areas of the drive, and save the optical drive. it just depends if the drive is going to be cooperative. SO WHY? when you put a cd/dvd in these drives, an arm comes up that prevents another disk from being inserted. One of the many types of failures with these drives, the arm will malfunction and the arm will come up and you cannot insert a disk in the unit, even though it's empty.
If you take the unit apart, you'll see what I'm talking about and you may be able to lubricate this so that it returns to normal function. if you go to my website you can purchase repair and send it to me, or just send to me and ill give you a free estimate
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gillian 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 138
总计 160,397
