My tablet screen fell off and my ribbon broke how do I install it back
Hi @faricawong
The screen will have to be replaced as the cable connection between the screen and the connector can't be fixed.
You should be able to re-use the flex cable that is plugged into the connector from the motherboard though
Here's the ifixit Samsung Galaxy Tab A (2019) 屏幕更换 guide that may help.
Search online for SM-T510/SM-T515 LCD display (if either of these model is your tablet) to find suppliers that suit you best.
这个答案有帮助吗?
Better pictures would help, the screen should be able to lift to 90 degrees to get better pics of the connector. Plus if it’s off why not remove the screen?
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 77
总计 3,177
7条评论
Hey their Farica, when you say that the ribbon broke, do you mean the ribbon cable for the display? Also, some photos would be very helpful for determining the savoriness of the issue and helping you achieve a solution. 在已经存在的问题里加入图片
由 Jacob Mehnert 完成的
@jmehnert i was just gonna ask for photos
what happened that caused the screen to fall off?
由 timtom77 完成的
@timtomissus the tablet overheated so the glue wasn’t holding the screen anymore one day I was watching my tablet sideways and it just fell off and I couldn’t turn it on anymore
由 Farica Wong 完成的
@jmehnert yes I went to the repair store and the person said it couldn’t be fix because the ribbon broke so I thought it’s impossible that just because the ribbon broke it’s not fixable anymore so that’s why I’m here asking for help
由 Farica Wong 完成的
@faricawong usually a ripped cable means a new display. Let's see the damage. Post a couple of good photos with your QUESTION. You wil need to edit your question to add images 在已经存在的问题里加入图片
由 oldturkey03 完成的
显示更多的2条评论
