跳转到主内容
加入维修社区 - 创建账户
The Dell Inspiron 1526 was a laptop released in 2008 known for the a swap-able face plates and its portability.
Motherboard problems for 1501 Insperion?
danny, you said that you fixed a insperion 1526 by replacing the little battery inside. i have the same problem with my 1501 and is in the shop right now diagnosed with a motherboard problem. how difficult is it to replace that battery? how hard is replacing the motherboard ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
In both situations you need to take apart the notebook. I'm not sure if is a guide for the specific notebook. If there is a guide and you follow the guide you will not have any problem.
完成的
添加一条评论
1个答案
已选择的解决方案
We unfortunately do not have any guides on our site for this computer yet. However, Dell does have guides for this computer here. Dell calls the mother board a "system board" and battery removal is in the "Before you begin" section. Battery replacement is quite easy. Mother board replacement is a fair bit more difficult, but certainly not impossible to do at home. As with any complex repair or dis-assembly, patience, organization and care are musts. Hope this helps you out, good luck.
这个答案有帮助吗?
得分 1
3条评论:
Phillip, I think louis may be referring to something like the CMOS battery...not quite as easy as the main battery ;-)
完成的
Doh! Is this the equivalent of what Dell is calling the "coin-cell battery"? They also have a guide for that and all it requires is for the keyboard and battery to be removed. A bit of a pain but still quite doable!
完成的
yep, I think that is it :-)
完成的
添加一条评论
添加你的答案
louis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 1,280
