跳转到主内容
Apple 2020年的顶级智能手机。iPhone12 Pro Max于10月13日发布并于11月13日发布,配备6.7英寸OLED显示屏,带LiDAR的三重后置摄像头系统和5G连接。iPhone 11的后继产品。 专业版
117 个问题 查看全部
power button stopped working after back glass replacement
I was replacing my iPhone 12 Pro Max back glass and when I went to go turn the phone on the power button wasn’t working. If i tap on the screen it turns on but if press the power button nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
This is a super common issue following back glass replacement on most iPhone models.There is typically a small gap in the chassis where the flex cables lives. It's all too easy to accidentally nick it when removing the old back glass. The little arm of the cable that handles the power button is extremely narrow. So it doesn't take much.
这个答案有帮助吗?
得分 3
添加一条评论
Hi Samarjit,
Yeah, that's the problem with back glass replacements - you end up exposing the phone's internal components to the high heat needed to get the glass off. In addition, since the wireless charging coil is exposed, it's susceptible to a random piece of glass or a slip of the prying tool.
On the iPhone 12 Pro Max, the power button is integrated with the volume buttons, the ring/silent switch and the wireless charging coil. Chances are very good either the heat or a tool damaged that assembly, resulting in a non-functional power button. Here's the part you need.
iPhone 12 Pro Max Audio Control Cable and Wireless Charging Antenna
Unfortunately I haven't been able to find any guides to replacing that part. The best I can suggest is to watch some teardown videos and use what existing iFixit guides there are to take out the components as they're encountered in the videos. Here are a couple to get you started.
iPhone 12 Pro Max Teardown - iFixit
iPhone 12 Pro Max Teardown - YouTube
Since you're blazing new trails here, it would be awesome if you could take pictures along the way and create a guide for others who end up with the same problem.
iPhone 12 Pro Max Audio Control Cable and Wireless Charging Antenna图片
产品
$39.99
这个答案有帮助吗?
得分 1
2条评论:
when I am replacing the power button it only clicks towards the middle. When I click toward the bottom of the button nothing clicks. Do you know what I can do to fix this issue? I have been trying for hours now
完成的
@samarjitdebnath I would take a look at the physical button itself and make sure it's undamaged and correctly mounted. There's an iPhone X guide to those buttons that will help with taking it out and reinserting it.
iPhone X Power and Audio Exterior Buttons Replacement
Start at Step 72 and be sure to check out iPhoneRepairGirl's video.
https://www.youtube.com/watch?v=hwlKlzsJ...
完成的
添加一条评论
添加你的答案
Samarjit debnath 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 169
总计 2,107
