跳转到主内容
加入维修社区 - 创建账户
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
washer doesn't fill with water
My washing machine doesn't fill with water.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch. For the correct part I would need greater detail on your exact machine model.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
It could have the switch that does it in a similar situation:
https://youtu.be/Fiv8ckoVAqo
thx,
完成的
添加一条评论
The pressure switch indicated by Mayer can be tested by disconnecting the tube from the tub and gently blowing into it. As the pressure builds a faint click should be heard from the switch unit ,indicating that the switch contacts have been activated. Another faint click will be heard only when you release the pressure. If the switch clicks before you release the pressure, then the diaphragm inside the unit is faulty.
Another cause could be a faulty solenoid coil on one of the inlet valves. There are usually two, (hot and cold). Isolate the power from the machine and disconnect the two wires from one of the solenoids. With a multimeter set on a low OHM's range, place the prods one on each terminal of the solenoid. If a reading is obtained, the coil is good. If no reading shows, then the coil is open circuit and a new solenoid valve is required. Hope this is helpful.
这个答案有帮助吗?
得分 1
2条评论:
+ nice addendum
完成的
Como llego al tubito, tengo q quitar la tapa que cubre la lavadora por detras?
完成的
添加一条评论
添加你的答案
steve acuin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 18
总计 4,636
