跳转到主内容
Repair guides and support for Windows 7 OS, an operating system released by Microsoft in 2009.
How can we fix Operating system not found'
When i turn on i see he says operating system not found
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@jasmeetsin53641 let's start at the beginning. When you turn what on? What device are you referring to? I suppose it is a computer. What have you checked? Did this happen all of a sudden or were you working on something? The more history and background that you provide, the greater your chance of getting a good answer.
完成的
添加一条评论
1个答案
Well you can try the following.
  1. Check the BIOS. You need to check for two things in the BIOS.
  2. Reset the BIOS.
  3. Fix the Boot Records.
  4. Enable or Disable UEFI Secure Boot.
  5. Activate the Windows Partition.
  6. Use Easy Recovery Essentials.
  7. Reinstall Windows.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jasmeet singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 225
