跳转到主内容
Frozen brake lines from rain
How do I keep brake lines from freezing? I have a Trek 7500 that has brake lines that freeze if water gets in the lines and temp drops below freezing. Have put teflon based lubricant on ends, put in warm basement, and they still freeze if all water is not out of lines. Help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
已选择的解决方案
This problem is somewhat counter intuitive solved by using the brakes more than nessesary. You should use the brakes so that they tear down the ice on the rim surface. As the rims are icey the brake performance are poor and therefore not stopping the bike. But it does come with a bit of speed penalty, so it is best to clean the surfaces by breaking at select places on the path you are riding. Downwards is of course a good place to break (even if you doesnt have to lower your speed) and you can pedal as a counter act to the resistant the braking cause. Apply the break force with just the right amount to tear the ice down without stopping the bike. The ice tears down by scratching from the brake pads but also from heat coming from the friction between pad and icey rim. On the flats a gentle brake force for a while can reduce the ice significantly. Do not use any lube or similar. Clean the rims with alcohol or equivalent and use the best brake pads you can find. The pads are not overly expensive compared to the crusial job they are supposed to do, so go for the best!
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Shahid,
Lubricate with antifreeze, let it run right down the cable. Or replace the cables.altogether.
Frank
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Shahid Raki 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 21
总计 1,274
