跳转到主内容
Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
67 个问题 查看全部
Wifi Greyed out and bluetooth
Hello, I got this phone in repair today it had already had the screen replaced on it before working on it the screen was an Aftermarket LCD not OLED I am thinking that the screen shorted out the board causing the wifi not to work anymore. Anyways I tried a new antenna and still greyed out anyone fixes this issue or know what I should do next or is it SOL?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
is the WIFI not working since it crashed? If so, it could be a problem with the motherboard. You have to separate the motherboard first. maybe the pin is disconnected
这个答案有帮助吗?
得分 0
添加一条评论
Check it’s on the latest update. Also if there is a security app on the phone remove it. I had a phone in with the same issue. They had some security app that had disabled the connections, when I removed it all the connections came back on straight away. If it needs updated you’ll need to hook it up to a computer.
这个答案有帮助吗?
得分 0
1条评论:
The phone has been factory reset
完成的
添加一条评论
Most likely cracked or torn pads on the interposer board or the Wi-Fi IC. You will need to separate the boards and check the pads between the boards before taking diode measurements of the Wi-Fi IC.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark D Schlossman 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 158
总计 712
