跳转到主内容
加入维修社区 - 创建账户
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
Boots from battery, not from power cord
I rescued the machine in question from being tossed in a dumpster. It will power up if I charge its battery in my own 17" PowerBook first. But it will not start up without the battery when I plug the power cord in, nor will it charge the battery. The power adapter I tried is the original that came with my (identical model) 17" PowerBook. I'm thinking the DC-in board needs replacing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
That is what I would recommend trying first.
完成的
添加一条评论
3个答案
已选择的解决方案
That's a very good guess. I'd do it.
这个答案有帮助吗?
得分 2
添加一条评论
I concur with the others here, this is the part you need.
这个答案有帮助吗?
得分 2
添加一条评论
The DC/In Board is a good place to start, but what power adapter do you have? is it a 65W or a 45W, if it's a 45W, the PowerBook can only charge off of it, and not actually run, the 65W can run, and charge at the same time.
这个答案有帮助吗?
得分 1
2条评论:
The adapter is 65W. It came with my 17" PowerBook G4 1.67 GHz low-res, which is the exact same as the one that I salvaged. The salvaged PowerBook neither powers up nor charges with the power adapter. Nothing happens at all. Only an externally-charged battery brings it to life. Which, frankly, surprised me.
完成的
You could check the connections to the DC-In board, and if that doesn't work, your best bet would be to replace it, if that doesn't do it, then the logic board, or battery might be defective.
完成的
添加一条评论
添加你的答案
fletcherism 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 2,175
