跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
459 个问题 查看全部
3DS Top screen error? Need to know what it is.
I've been trying to look around online and figure out what's wrong with my 3DS XL, but nothing really feels... right? Something with the top screen and a weird lighting issue. It's not brighter than the bottom screen, I think the colors are just screwed up? (black screens occasionally turn green, stuff like that.) I can't tell what's wrong with it, and I sorta need to know that in order to fix it. Like, what part I'd need to repair/replace or if it's salvageable in the first place.
Here's a video of how it looks. Anyone know what's up? https://youtu.be/244UK7adEWs
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Take a look at the board/connectors. Unless there's obvious damage, my guess would be a faulty connection in your upper lcd's connector or cable.
这个答案有帮助吗?
得分 0
2条评论:
There's not really any obvious or critical external damage, it just started doing that one day.
If your guess is right, is there a way to fix it? If so, what part(s) would I need? Not super experienced with this.
完成的
@jscriggins If it's the cable, you should be fine just replacing the lcd. But if you have a bad connector, you'd probably be better off taking it to a repair shop unless you have experience with board level repairs
完成的
添加一条评论
添加你的答案
jscriggins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 112
