跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
What heating tool do you use?
I'm looking at getting a good tool for opening glued MacBook Unibody display.
What have you used? What was most successful, what didn't work so well?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
UPDATE
I got the inexpensive gun from iFixit, it does the job for me: Heat Gun
完成的
添加一条评论
4个答案
已选择的解决方案
I use a Bosch Heat gun 1942: http://www.boschtools.com/products/tools...
And four heavy duty Spudger:
Heavy-Duty Spudger
You just take your time and do not leave the heat on one spot too long. But follow the guide posted on iFixit.com and it will come right off. It will take a good 10 or so minutes to remove the glass. So do not rush it. You can crack the glass if you hold the gun in one spot too long or pry the side too fast before the glue is loosened.
这个答案有帮助吗?
得分 3
添加一条评论
i use for that a cheap heat gun (~14$)
the temperature range is from 250°F to 1100°F
it can also be used for bga reflowing - but it's not as good as a real hot air station, even the cheap gordak/aoyue stations are better - but if you only need something like that for one or two boards - you can use a common heat gun
这个答案有帮助吗?
得分 3
1条评论:
+ thanks
完成的
添加一条评论
I used an old hairdryer and a suction cup from my GPS.
这个答案有帮助吗?
得分 2
添加一条评论
Use a suction cup, spudger and a hairdryer with a flat tip. If you have some flat frig magnets to slip under the glass so it won't reattach even better.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 4,074
