跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
286 个问题 查看全部
Help me troubleshoot my iMac.
I replaced thermal paste, replaced the HDD with a SDD, and cleaned out the fans and case. No accidents, all connections accounted for. Now, absolute silence and no picture when power button is pushed. I've re-opened twice after going to google and to apple support and I can't find anything wrong.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I'm afraid this did not help. I have purchased a replacement power supply from eBay. I have some compatible SODIMMS which will replace the current ones. I 'm arranging for someone to help me check the power switch ( this is a stretch, I know). If this doesn't work, I'm done, and I will part it out and sell it. Thank you for your help.
完成的
添加一条评论
1个答案
已选择的解决方案
You likely didn’t sit the CPU chip into the socket correctly. The design Apple went with is a bit tricky! Go back removing the heatsink and inspect the chip and the socket for damage if you are lucky, reseat the chip but soften the springs a bit.
这个答案有帮助吗?
得分 0
1条评论:
I'll let you know. I'm grateful.
完成的
添加一条评论
添加你的答案
todoroffc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 35
