跳转到主内容
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
54 个问题 查看全部
My VCR tape windup spool sticks, causing distorted video
I opened it and saw the take-up spool was sticking, but why?
I already tried head cleaner but it did not help it. Record causes spots with nothing recorded and "blip" sound, when played back on good vcr. When good tape is played back it causes a short "skip", is the best I can describe. It is Samsung VR5704. It started a few months ago, before that it worked great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@arenard Are there any belts in this unit?
完成的
I opened it and I see no belt. I watched it play and I noticed that the spool winding up sticks a little when this happens. Everything else looks smooth running. As if there is a drag. I wanted to stop the tape but I pressed play while it was playing and that did the same thing and caused it to continue to drag for awhile.
完成的
添加一条评论
2个答案
最有帮助的答案
There are numerous possibilities here all depending upon the model of the VCR. If there are no belts (as indicated in one update), then the most likely cause here is a defect in one of the gears. It could be a broken tooth or debris in the gear itself. Some VRs use tension bands that could have debris on them as well. Please update this with the make and model. More details can be provided.
\Dan
这个答案有帮助吗?
得分 2
1条评论:
@abrsvc the OP had the make and model clearly identified within the question. I bolded it for greater visibility.
完成的
添加一条评论
First off using a head cleaner on a vcr is a big no no. Second you need to clean it by hand with rubbing alcohol and a cotton cloth, then check on the bottom of the deck and see which belt is broke.
这个答案有帮助吗?
得分 0
2条评论:
@tazmaniac_37752 the OP already pointed out that "I opened it and I see no belt"
完成的
Yeah but usually they open from the top and the belt is on the bottom and usually yuh have to un bolt the deck from inside and take it out to see the belt.
完成的
添加一条评论
添加你的答案
arenard 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 83
