跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 游戏主机的一款更实惠、纯掌机版本,具有集成式 Joy-Con 控制器和稍小的屏幕。于 2019 年 9 月 20 日发布。
Why is my Nintendo Switch Lite backlight not working after shell swap?
I attempted to reshell my Nintendo Switch Lite but there is no backlight when I turn on the console. I can hear sound and the buttons work, and I can see the screen when I shine a flashlight on it. The ribbon cables look fine and I unplugged the battery first so nothing would short. I have had a lot of experience with repairing Nintendo consoles, but I am not sure what is wrong with this one. Should I try to replace the screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
I think it might be this cable here because I damaged one with my tweezers. My tweezers ended up being bent upward on the end, so I had to replace the one that connects the motherboard to the daughterboard. [image|2876773]
由完成的
@nintendog909 that is great. Good to know that the ribbon cable is okay :-)
由完成的
I'm having the same issues I thought it was the screen so I replaced it but it still has the same issue I even replaced the cable that goes from the main board to the one on the motherboard on the left side and when I turned it on it still has no picture the sound works but the left button are not working properly do I need to buy a new left motherboard?
由完成的
添加一条评论
2个答案
最有帮助的答案
Disconnect the battery and remove the game card reader. Disconnect and reconnect the black ribbon underneath making sure it’s seated all the way in. Also make sure the other ribbons are all the way in. No backlight is usually caused by an incorrectly inserted ribbon.
Update (02/28/2023)
I’m sure this is the backlight connector. Is this one connected correctly?
这个答案有帮助吗?
得分 1
3条评论:
Thank you! I have tried this multiple times and I still haven’t gotten it to work… I know that nothing is shorted, so I think one of the cables could have gotten damaged. I replaced the cable that connects the motherboard to the daughterboard but the backlight still doesn’t work. Is there a way to replace just the backlight or do I have to get a new screen?
由完成的
@nintendog909 I think you’ll be looking at a new screen. Can you post pics of what you think is damaged at all?
由完成的
According to the repair guide, that is the right joystick cable.
由完成的
添加一条评论
这个答案有帮助吗?
得分 0
4条评论:
I forgot to mention that I did use my bent tweezers on the cable that connects the backlight!
由完成的
@nintendog909 To be honest they look ok. I can’t see any damage. The bottom one I think is the one for the back light. The top for shoulder buttons? I think you’re looking at a new screen unless I’ve missed something.
由完成的
Okay! Thank you so much for your help!
由完成的
添加一条评论
添加你的答案
Bailey Bryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 100
总计 7,747
