跳转到主内容
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
Cartridge slot replacement - Burnt pad on the board
Hi everyone!
I recently came upon a broken DS Lite whose cart reader was removed, so I want to install a new one. Problem is, one of the pads seems to have been burnt off, as shown on the pictures below. Is there any way to bridge the corresponding pin on the reader to another location on the board ?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
It looks like that all the pads correspond to a via (through hole) above them. Once you clean up the solder joints with some solder wick and then alcohol, you will see that this broken pad probably got torn off that big green trace that has the writing "CL5" in it.
If I were you, I would scrape off some of that green solder mask on that wide trace to expose the copper, making sure not to damage the via and run a jumper wire or a jumper pad to that pin.
Hope it helps!
Update (02/26/2023)
You are absolutely right, looking at the board that you linked, that pad is not connecting to anything so you don't have to worry about it. It happens that some of the pad are 'No connects' which means it is easier for your repair as you can just leave it as it is.
这个答案有帮助吗?
得分 2
1条评论:
Hi,
Thank you for your answer. I did some research and found this picture of the circuit :
https://bitbuilt.net/forums/index.php?at...
The via you are talking about does not connect to the pad that is missing. In fact, that pad doesn't seem to connect to anything. That might seem like a dumb question, but what use could a dead end pad like this one have?
(Shoutout to KreativDax on the BitBuilt forums for their amazing work, here's a link to the pictures of all the layers of the DS Lite PCB for those who are interested : https://bitbuilt.net/forums/index.php?th... )
完成的
添加一条评论
The area you're concerned about shouldn't really be a problem. What's the second area? Looks ripped up too.
这个答案有帮助吗?
得分 0
1条评论:
That's were one of the legs of the cart reader was soldered into place.
完成的
添加一条评论
添加你的答案
K. S. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 37
总计 571
