跳转到主内容
加入维修社区 - 创建账户
一款任天堂为 Switch 系统生产的无线、传统的视频游戏手柄。型号:HAC-013。
3 DAYS NOW Motherboard replacement IS SOLDERING required?
So I have a pro controller and I don’t wanna have to purchase a new controller, so I was thinking of replacing the motherboard instead of having to replace the joystick, and I was wondering if the rumble packs have to be soldered without the controller working?
So you know what’s wrong with the controller the right joystick is completely smashed like it’s not repairable
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Anyone? I need to know
完成的
I FORGIT TO MENTION
The joystick stick in side the modular is broken in half UNREPAIRABLE and that’s on the motherboard so I want to replace it do I need the rumble pack connected to work?
完成的
添加一条评论
2个答案
已选择的解决方案
Looking at this then the answer to your question is yes, they are soldered. Easy to remove. Just apply the iron to the other side of the board and when the solder melts pull the wire out. Reverse the process to reattach them.
这个答案有帮助吗?
得分 2
5条评论:
I meant DO I need them for the controller to work I can’t solder
完成的
@sqwerks_3464 No, you don't need them. I have a ps4 controller I disconnected the motors on and it works fine.
完成的
Well are you sure
完成的
@sqwerks_3464 yes, think of it as turning off the rumble feedback in game settings. The board will still send power to the connections whether they are connected or not. I’m definitely sure it will work fine without them.
完成的
@strongbow thanks for the contact i will choose your answer now thanks for the help
完成的
添加一条评论
If you broke you joystick, you should replace the joysticks, not the motherboard, as you're putting extra work on your self that is unnecessary
heres some links to fix your pro controller
任天堂 Switch Pro 控制器操纵杆模块更换
Nintendo Switch Pro Controller Joystick
happy repairing!
Replace a malfunctioning joystick in a Nintendo Switch Pro Controller.图片
产品
$12.99
这个答案有帮助吗?
得分 1
7条评论:
Well, the issue thanks for the answer to the motherboard is dirty and is very old. The charge port is also kind of busted and I was just gonna replace the motherboard since I am on me featuring NOVICE level of soldering, and I was just wondering if I have to replace the rumble packs and Saturday March the new motherboard in order to be able to use the controlLer
完成的
could you add images of the motherboard?
also you can clean the motherboard if its very dusty, no need to replace Precision Cleaning Kit
完成的
The mother board has glue on it like super glue
完成的
Also if the board is dirty I don’t have any soldering equipment and no practice yet so I just want to scrap it for later and replace it is that fine?
完成的
well, if theres glues thats not on a normal mother board, then you should replace it, and order joysticks to put on it, and then you should be good to go
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Sqwerks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 49
总计 641
