跳转到主内容
GoPro Hero5 Black是GoPro于2016年10月发布的高清防水运动相机。具有4k分辨率录制和语音控制,触摸屏显示和内置WiFi功能。
Will not detect or read and SD card
It just keeps reading SD card error
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi
Sometimes cleaning the SD card slot with some isopropyl alcohol and a toothbrush can help to resolve this issue
Also the Hero 5 was known for the water resistance being a bit of a hit or a miss so if it has been exposed to water I would recommend using this guide to check the device for water damage
Here’s a disassembly guide
GoPro Hero5 Black Motherboard Replacement
Once again isopropyl alcohol is good at cleaning corrosion but water damage can sometimes need professional work
I would also check the formatting of the SD Card,make sure the GoPro can read it:-)
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
得分 1
1条评论:
Try another SD card before you get to the point of disassembly, i've had some SD cards fail in odd ways like that before!
完成的
添加一条评论
添加你的答案
tourette88 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 313
