跳转到主内容
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
Artifacts all over the screen…
What could be causing this?
I need a second opinion before I buy more ram
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
19条评论
What do they look like, Ben? Can you add a picture to your question?
完成的
@oldturkey03 - :-[…
Hey @hellomacos how’d you like to fix a GPU fault? Well today’s your lucky day!
完成的
@beanman56
Have you tried cleaning the ram slots?
My Mac Pro did something similar to that when some dust got into one of the slots
完成的
@hellomacos - I’ll try it, when I opened it I was greeted by someone’s pet dust bunny.
完成的
Well it’s better(sort of ) but then it went back, I think it’s a ram problem. Thanks @hellomacos
完成的
显示更多的14条评论
添加一条评论
1个答案
最有帮助的答案
Hello Ben,
This's cpu overheating problem (GPU sector) and just of beginning of the problem. On this moment cpu reballing will enough.
这个答案有帮助吗?
得分 1
12条评论:
@tojaert - I'll try your fix after my heat gun gets here.
完成的
:-) heat gun is nor enough. Just will destroy a working computer. Don't do that way. Find proper repair shop.
完成的
@tojaert - well it doesn’t work anyways so…
完成的
this is a basic mistake among amateurs... "it doesn't work anyway, so...". You're going to kill this motherboard with that way.
完成的
@tojaert - Reballing a chip is not that trivial! The chance for it to work with just a heat gun is less than 25% !!
To do it correctly requires a rework station so the logic board is at the correct temp and the rework stations chip heater is set at the correct temp and after the chip is mounted the board and the chip,are,properly cooled down so you don’t create solder fractures or cold solder joints.
Even I don’t tempt doing it any more as it’s not easy to do and unless you do it often you often mess up!
Keep in mind this series uses a dedicated Radeon 9200 GPU chip so messing with the PowerPC chip won’t fix the graphics issues.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 28
总计 464
