跳转到主内容
加入维修社区 - 创建账户
苹果公司的 2021 款 iPhone 于 9 月 24 日发布,配备 6.1 英寸 OLED 显示屏、双 1200 万像素摄像头系统和五种可选颜色。该手机为 iPhone 12 的继任者。
Screen Replacement + no service
Have been doing phone repairs for 2-3 years now and never had much of a problem changing out screens or even housings. Recently did an iPhone 13. Completed everything gave it to the client and everything worked. About a week later he brings me the phone back and has no data available. He can make phone calls and send text messages, but can’t use iMessage or access the internet. What could be causing this? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Preston,
you need to move on to the next stage of learning, which is the level of microelectronics and motherboard. In this case, a lot depends on the cause of the original fault (the reason for replacing the screen - probably a fall). You need to check the operation of the motherboard components - in this case the WiFi&BT chip. Probably, the fragile connection broke during the fall and makes itself felt. You need to remove the motherboard and check the connection of the interposer to both parts of the motherboard. Soldering awaits you (fortunately at a very low level).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Preston Harmon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 253
