跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
I have a problem with power
Hi !! Idon't knox why my phone 6s is not working i have problem with power
i thinks is from ic charge if you can help me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
does it turn on when you plug it in?
does it vibrate or make a sound without the screen turning on?
does it make a popping sound or does the screen flash?
is there any damage you can see?
完成的
@timtomissus has some excellent questions for you that will help us figure out what's going on with your phone. I'd like to add a couple myself.
If you plug it into a computer, is it recognized?
Has anything changed with the phone recently; an update, getting dropped, getting wet, etc?
Have you tried a different charger and a different cord? Made sure your outlet works?
完成的
@dadibrokeit
teamwork! :D
完成的
It is now working but it restarts automatically hahahaha
完成的
添加一条评论
1个答案
已选择的解决方案
It's working now, eh? What did you do that got it sort of working?
If it's constantly rebooting we refer to that as a boot loop. iPhones have a standard reaction to unrecoverable hardware or software errors; they reboot the phone. As it turns out, the phones scan their sensors every three minutes, so if you've got an issue with one of the sensors, that's enough time for the phone to boot, run for a little while, then after three minutes it's time to scan the sensors. Oops, there's an issue; think I'll reboot. Rinse and repeat ad infinitum.
Fortunately, iOS logs those reboots and the reason for them. One of iFixit's contributors has written an excellent Wiki article on those reboots, or "kernel panics" as they're technically termed. Along with explaining the causes behind them, there's also information about how to find the logs that will show you why the phone rebooted.
iPhone Kernel Panics - iFixit
So my suggestion is to read the article, go retrieve your panic log or logs and either screenshot or cut'n'paste the first page or so and add it to your question. We can take a look and see if we can tell you what you need to do or replace to get your phone working again.
Adding images to an existing question - iFixit Repair Guide
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
aminegio1186 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
