跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
MacBook Pro 2017 (A1708) unable to see OWC Aura Pro NT SSD
My MacBook Pro 2017 (A1708) SDD has been giving me issue, it works intermittently. When it works it works as expected and other times boots up to a flashing question mark folder.
I updated the machine to MacOS 13.2 and swopped out the SSDs and was not able to see anything in disk utilities. The drive does not pick up at all.
Reinstalled the old/original Apple SSD and the machine works the same as before.
Any advice will be appreciated, thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What is the version of macOS which you are working with? Both the original SSD as well as what you installed onto the OWC.
This sounds like a file system type of issue.
这个答案有帮助吗?
得分 0
9条评论:
I had macOS Ventura 13.2 installed on the original Apple SSD. I was unable access the OWC drive in disk utilities, using command + r or with a bootable USB.
Not sure if I am missing a step to get the drive visible in disk utilities.
完成的
@glegrange - The version of macOS on your bootable USB drive maybe the issue! What is it?
完成的
@danj macOS 13.2 as well, the same has installed on my machine.
完成的
@glegrange - This is quite odd! So both the original and thumb drives are running the same macOS version.
Often we see issues when mixing file system versions like Sierra or older (HFS+) Vs anything newer High Sierra and newer (APFS). The systems firmware gets upgraded so it can boot from the newer OS and Disk Utility also gets a few tweaks.
Have you spoken to OWC? I would do that you might have a bad drive here.
完成的
@danj I have returned the SSD and waiting for the refund to be actioned. Seems a bad drive is the only explanation.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Gareth le Grange 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 167
