跳转到主内容
Epson EcoTank L3150 Wi-Fi All-in-One Ink Tank Printer
20 个问题 查看全部
Black Ink Not Printing on Epson L3150 Printer After Refilling Cartridg
I have an Epson L3150 printer that stopped printing black ink after the cartridge ran out. I refilled the cartridge manually, but the printer still doesn't print in black. I have tried cleaning the print head several times, but it didn't solve the problem. The printer prints in other colors normally. Could you please help me troubleshoot and fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
1个答案
Try to do deep cleaning, this happen because your ink could not reach the head yet.
After deep cleaning it will reach the head and you can use your printer again, otherwise be careful when injecting the ink tank manually. Something terrible could happened.
这个答案有帮助吗?
得分 -1
3条评论:
Downvoting this answer as this is merely a surefire way to kill your printer early. This shouldn't be in the user-accessible service modes.
完成的
@nick are you sure with your word about surefire?
do you want to see more surefire caused of the Quote ''Authorized service center" caused. Inbox me I will show you more newest product because of surefire.
完成的
My epson L3150 couldn't print in black and white whereas there were no issues in color. I did head cleaning, nozzle cleaning, deep cleaning but nothing helped. Then i opened the tray and found out that the black ink couldn't reach the head. So i took an injection syringe and pulled all the residue ink from the pipe. Then connected the pipe as it was before. Now its working absolutely fine. But, I would advice that only those people with basic technical knowledge should try opening the printer.
完成的
添加一条评论
添加你的答案
Mohammed Z. 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 28
总计 2,207
