跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Pink lined display screen
Has anyone seen this before? I have the A1708 model.
Laptop has not been damaged or dropped. Worked fine and this randomly happened. The screen appears to come on around the 45 degree angle sometimes, which leads me more in the direction of some connection inside with the screen? Any guidance and feedback would be appreciated!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly yes, Apple had a bad run of displays. Most failed within the first year warranty. I’m surprised yours held out four years!
When the T-CON board logic heats up it causes this issue. I would visit an Apple Store, see if they will still cover the repair as a warranty exemption. See if you can get them to cover the labor cost at least.
If not, it’s going to be costly! MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s the guide 2016后期带功能键的13寸MacBook Pro显示屏组件更换
Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.图片
产品
$444.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Traci Babcock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 89
