跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
Replacing hard drive with SSD or PCIE
I have been wanting to replace my SATA hard drive for a while with an SSD for awhile, but didn't want to open up my iMac. My power supply has been failing and I am now forced to replace it. While repairing this I want to replace my Fusion Drive with a SSD. I initially was going to buy the SSD upgrade kit, but then read online it would be even better to replace the PCIE SSD. Is this the case. If I were to replace this, can I remove both the PCIE 32gb flash drive and the 1tb SATA drive and just replace with a 1tb SSD PCIE? Is there an issue with the fan temp? I don't need the extra storage of the SATA. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would first get all of your data on a backup, and then when you are done replacing the drives you would have to redownload the Apple software. Also here are the guides: SSD, HDD, and Power Supply.
iMac 27" 2017 Hard Drive图片
指南
iMac 27" 2017 Hard Drive Replacement
难度:
中等
1 - 2 hours
iMac 27" 2017 Power Supply图片
指南
iMac 27" 2017 Power Supply Replacement
难度:
中等
1 - 2 hours
iMac 27" 2017 Blade SSD图片
指南
iMac 27" 2017 Blade SSD Replacement
难度:
中等
1 - 3 hours
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tyler Riddick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 181
