跳转到主内容
2022年13英寸MacBook Air的维修指南、支持和故障排除信息,采用苹果的M2 SoC。于2022年7月15日发布,型号为A2681。
Anyone know the SMD device for this location?
When I was cleaning it, it blew off with a brush...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
7条评论:
@imicrosoldering This may be your cup of tea.
完成的
Was it a community meant to be ironic? This was too ambitious.
完成的
Tomoharu Kobayashi What is the board number of your logic board?
完成的
hi
It's A2681.
完成的
Tomoharu Kobayashi Yes, that’s the model number, but what is the logic board number?
完成的
显示更多的2条评论
添加一条评论
1个答案
After reassembling does the system work at all? If it does what does diagnostics tell you?
It’s going to be a while before the schematics and board-view drawings leak out of Apple or someone reverse engineers things.
I’m surprised you needed to clean the board, did you have a liquid spill? If not where was this system that got so dusty? For such a new system there really is no need to go this far. At best a can of can’d air to blow the fan blades and surfaces is about all you should need here and after a good hard year of service. I would focus on making sure the work area is clean and not sitting on any fluffy cloth like a bed spread and keep the 🐈‍⬛ off!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tomoharu Kobayashi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 309
