跳转到主内容
加入维修社区 - 创建账户
M2是苹果公司针对Mac的片上系统的第二次迭代,具有集成GPU、CPU、RAM和其他组件,可提高性能和效率。Mac mini中的基础M2有一个8核CPU,有四个高效内核、四个高性能内核和一个10核集成GPU。通过型号A2686识别。
Is my Mac Mini M2 broken?
Hi there.
I have MacBook Pro 2018 with CRAZY over 3000MB/s and boot time was like 30 seconds - and now I got now Mac Mini M2 BASE MODEL which means 1500MB/s and....... boot time is about..... 7-8 SECONDS (from power button click to login screen) - both systems on THE SAME macOS!!! It is nearly the same time as MBP 2018 too to Wake Up !
HOW??!?!
I've asked Google for boot times on MacBook Pro and Air M2 and EVERYONE says average 15 SECONDS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Of course you are starting the systems from a cold boot too? Your numbers don’t line up. I’m sure you are waking your MacBook Pro from Sleep which is very different from a cold boot up you are doing with your Mac Mini.
As far as disk performance are you using BlackMagic to compare? I think you’ll find the M.2 might be slower if you didn’t get the larger storage option. The number of Flash chips has a large bearing on how fast the storage reads or writes. The low end model only has one chip unlike the larger storage options.
这个答案有帮助吗?
得分 3
3条评论:
yes - BOTH systems startup from cold start.
Then I was talking about how shock was to me mini M2 wake up.
7 SECONDS to boot time in mini M2?! I just cannot believe
由完成的
So... you're asking if your Mac is broken because it's booting so fast???
Lol, take your wins where you can get them, my friend.
由完成的
Please take the way more powerful M2 chip over the Intel chip in your MacBook into account. The M2 system as a whole is a multitude of times faster than your MacBook. That’s probably what makes the difference.
由完成的
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 36
总计 1,535
