Aorus x570 I pro wifi missing components
Hi there,
I have some missing components off of the bottom of my motherboard. If anyone could help me find out what they're and where i might order some it would be greatly appreciated. I tried to get as clear of a picture as i could.
I'm not sure if anyone who has the same motherboard could test the components for there ratings? As far as i can see there are 2 resistors and a transistor at the bottom missing and at the top 2 resistors and i'm not sure what that on is. Based on a google image search it's black with a small contact on either side. It looks like a diode but i'm not 100% on that.
I don't know if anyone has a schematic of the board i don't know if it will show what they're there.
Thanks in advance :)
Update: i have uploaded some photos from google images of what they should look like if that helps.
2nd Update: i have included a pic of a closeup i found of someone's board that fried but it was in the same area as where my components are missing. i have also taken a close up of the spot where mine is missing. all of the transistors in that area have
701 z on them and they all have matching resistors or capacitors coming off of them so i have an idea they're the same as the one's next to them.
the one's on the burnt motherboard pic say tcm 92 i would have thought they're the same but i'm not an expert on these sort of things
i still can't get a good picture of the components at the top of the board near the audio ports. so i am still not sure what they're
Update 3:
Ok, from what i have learn't it appears at the top of the board by the audio ports the missing parts are 2 varistors and a diode and at the bottom i am missing a transistor, capacitor and a resistor.
The components beside the transistor seem identical in looks and the markings on the transistor match in other photos of the board.
I have a basic multimeter at home, is there any way i can test them to see what there ratings are?
All of my conclusions are really guess work so i might be well off.
I found a chart with the same marking number on the transistor but i am not sure if it is the right part.
I have added a pic
i am near giving up with the board. if anyone can help me get the parts i can sort you out a drink or something? i don't know what to do anymore.
thanks again
Update 29/5/23
I have found the transistor and replaced the cap and resistor on the board. i managed to get them off of a donor board and managed to match them with some that was close by.
the board is now working and running well.
all that's left is the diode and the 2 missing components near the audio connectors.
I don't really have a clue what the rating are of them as i don't have anything near by that resembles them. and i take take anything off to check the rating as there is nothing there.
i don't know if anyone has the same board that could get the ratings for them for me as i can't seem to find a schematic for the board.
thanks again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论:
sparkz155 give us one more picture but this time off the whole card so we see where the components are located in relation to the complete board.
完成的
Hi, thanks for your reply. I have added some photos i found on the net. Hope they help give an idea of what they're.
完成的
@sparkz 155 I got some of the Aorus schematics and BV just trying to see if they are compatible.
完成的
That would be awesome if you do have one for my board. I tried asking gigabyte customer support if they could check their schematics for what they are but they just suggested to RMA it. I'm pretty sure knocked off components aren't covered by RMA and it out of warranty anyway. It was worth a shot i guess.
Thank you so much for helping me with all this :)
完成的
@sparkz 155 ok so I have teh BV but have trouble opening those. Bare with us. WE have not forgotten.
完成的
显示更多的2条评论
添加一条评论
