跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 于 1996 年 6 月 23 日发布,型号为 NUS-001。它是任天堂的第一款 64 位游戏主机,也是在 Switch 发布之前唯一的 64 位游戏主机(GameCube、Wii 和 Wii U 虽然可以进行 64 位浮点运算,但并非真正的 64 位架构)。
How do I get the nintendo 64 to work on modern TV?
I have a Nintendo 64 which is in perfect working order but cant seem to get a picture on my Samsung plasma tv and i have tried searching the channel too. Do i need to purchase a different cable or anything?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
9条评论
James Bryant, what cable are you using? The WII cable would work as well as an NES AV/Component cable. Your TV probably has the RCA or S video in, insert the cable into those, make sure that you select the right video source on your TV. Let us know what TV you have in case it should still not work.
完成的
Im just using the nintendo cable. should i purchase the wii cable and try it?
完成的
That is the way I would proceed. which Samsung TV do you have?
完成的
maybe & maybe not because I have a sanyo plasma tv & it works with all my game consoles like my gamecube,wii,& PS3
完成的
On my sanyo plasma tv the yellow,white,&red are on the side & the top plug-ins on the tv
完成的
显示更多的4条评论
添加一条评论
4个答案
已选择的解决方案
You should be able to use the standard Nintendo RCA cables (such as used by the Wii and also the SNES). If you get no video when using this the problem may lie with the console or possibly the game. Any dust or wear on the contacts will cause the system to give no video output at all.
这个答案有帮助吗?
得分 2
1条评论:
The Wii video cables are incompatible with the N64 due to a different connector. Only the SNES, N64, and GameCube can interchange cables.
完成的
添加一条评论
I'm not exactly sure what the issue is (if your sound is getting through, the TV must not support that resolution) but this should fix it. Or, if your TV has a VGA input an A/V to vga also works.
I have the same problem, except that my gamecube doesn't work with my A/V receiver. It works when I plug it into my TV, though. If your TV has the setting for it, change your resolution to 680P or 480P. Hope this helped!
这个答案有帮助吗?
得分 2
添加一条评论
some times its the resolution of your Tv its too bigger
这个答案有帮助吗?
得分 1
添加一条评论
Maybe try different video cables. I'd try RF to see if that fixes your issue. Most smart TV's have an RF port on them. Had an identical issue, Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Bryant 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 59
总计 46,738
